car shuts down then turns back on..
Old 11-13-2013, 10:15 PM
bonesaw's Avatar
Default car shuts down then turns back on..
i have a 1996 volvo 960 2.9L I6
i had to replace my water pump so i had to take off the timing belt. i took the belt off and did what i needed to do and then put a new belt on and made sure the timing marks were all good. i rotated the crank a couple times to test then i started the car and everything was cool. i drove a little and then parked. it sat for about 3 days and then i took it out for a spin. i drove for about two minutes and while stopped at a red light i felt the car shut off and then on again almost instantly. the only reason i think it shut off is because i saw the gauges drop to zero and then return to where they were. then a second later the check engine light came on.
so im wondering if messing with the timing belt is the cause of this.
then i fooled with the car a little more and every time i turned it off the engine cooling fan on the radiator stayed on for a longggg time... and i know this might be typical for some cars but my car has never had the fan on this long (owned car for about four years). then after i let the car run for a few minutes the fan shut off (while engine was running) and now the temp gauge is reading cold and below (looks like it off). do i need a new thermometer? or what should i do about this
thanks id appreciate any advice
Old 11-16-2013, 10:02 AM
lev's Avatar
lev
lev is offline
Logical to look at T belt... Make sure a tooth is not off. The fan issue should not be related BUT weird stuff happens...
Address the running first, see what happens with fan once car is running right.
Iggyomega
04-10-2020 07:23 AM
kilkennycats
12-24-2014 04:17 AM
Volvorator
12-30-2010 11:43 PM
Wanttobecool
03-11-2009 07:21 PM
TERRY940
09-28-2005 09:06 PM
Quick Reply: car shuts down then turns back on..
