so I am loosing coolant in my 960 2.9 but no leaks can be found top radiator hose has no pressure but it is not over heating but I can smell it with the window down on the drivers side . All the hoses get hot . Need help .
Check your radiator cap
Especially if its aftermarket.
make sure it is rated at the correct pressure. The grey cap is much higher pressure than the green one, and some cars can take the grey no problem. Leaks often occur in this area.
