More PNP Switch Confusion
Old 10-20-2014, 04:55 PM
Spalding's Avatar
Default More PNP Switch Confusion
So my 97 960 recently showed the transmission fault code and W/S/E flashing lights. Two things have started to happen:
The car will not turn on unless it is in Neutral. Also, the engine just revs when the gas is applied while in Drive (D). I eventually have to turn the engine off, let it roll back a little in Neutral, and then turn the car back until I get power in Drive (D). Once I've got power, the car drives perfectly fine through all of the gears like there's nothing wrong at all.
Somedays the light isn't on, yet I still have to start it in Neutral.
This afternoon I put the car up on blocks without getting the code checked.
Does this sound like a PNP issue?
Old 10-25-2014, 12:31 PM
lev's Avatar
lev
lev is offline
Sounds like the transmission is done for.
Old 10-31-2014, 02:03 PM
Blue91SL's Avatar
Does the '97 960 share a trans with the '95? If so I have one available to pull at a local yard.
Old 11-01-2014, 11:23 AM
Spalding's Avatar
So I swapped out another PNP switch I had laying around and the problems have been remedied. I'm unsure how long the transmission will remain fixed but its been 5 days with no reoccurrence of the problems listed above (keeping my fingers crossed).
960 rookie
11-29-2007 06:16 PM
jayturk99
09-17-2007 07:14 PM
rich850
08-30-2006 08:13 PM
waldos960
01-03-2006 09:01 PM
tipp80
07-20-2005 05:31 PM
Quick Reply: More PNP Switch Confusion
