Reduced power/misfire on 97 960 Turbo - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-20-2017, 02:23 AM
Default Reduced power/misfire on 97 960 Turbo
Just bought a 97 960 turbo with 220k on it. It runs extremely rough and loud and has greatly reduced power almost as if a couple spark plugs are fouled. However, there's a good sized hole in the exhaust right before it hits the cat and I'm wondering if that might be causing the issue?
The guy I got it from said the head gasket was bad and that's why it's running so rough, however every check that can be done without tools tells me it's not a headgasket. It doesn't even get hot! No, I haven't done a compression test or anything like that but I'm thinking this hole in the exhaust may be the issue...thoughts?
Either way, I paid $200 for the car and it's in almost perfect shape so it's just a cheap project for me. Never even owned a Volvo so this is a new experience lol.
Thread Thread Starter Forum Replies Last Post
Random Multiple Misfire, Fuel Trim System Too Lean, Cylinder 5 & 6 Misfire divinedavis Volvo S80 3 02-28-2016 06:33 PM
Slow take off/reduced power kjourdan Volvo S60 & V60 5 11-09-2012 07:11 AM
Reduced power engine problem! Lambsvolvo Volvo S80 1 06-01-2012 08:43 PM
Rough idle, stalling, reduced power 04v70 Volvo V70 1 08-19-2009 05:49 AM
Reduced power engine service required nickmcd Volvo V70 3 06-15-2009 07:26 PM
Tags
960, exhaust, head gasket, misfire, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
