shifter stuck in park - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 10-15-2011, 10:35 AM
Default shifter stuck in park
I have a 97 960 the shifter is stuck in park does not release when I depress brake only when I push in manual shift button, dealer said it was solenoid ? can I replace ? how hard is it to do? can anyone explain how to do ? thanks in advance
Don
Old 10-16-2011, 10:57 PM
Welcome to the forum. Check forum for PNP switch problem and fixes. Common problem. not hard to fix.
Old 10-17-2011, 11:58 AM
There is also a chance you have a bad ignition switch. If you start the car and turn the key back just a little, it may start working properly. It's a common problem with Volvo's built between '93 and '99. Every 960/S90 I owned had the problem. I kinda liked it, it was like a security feature. You may need to get a new ignition switch from FCP or somewhere and replace it. Not as bad as it sounds. The ignition switch is on the other side of the steering collum from where you stick the key in. It has about 15 switches in it that control a lot of stuff. About 75% of them will work when you turn them back a little, the others will not. The part at FCP is about $55.
Common symptoms are:
  • Will not come out of gear.
  • Windows will not come down.
  • Lights don't work.
  • Radio won't come on.
  • Turn signals don't work.
  • Lights don't come one.
  • Cruise control won't engage.
  • The list goes on...
The car will run and drive but most accessories will not work.
Thread Thread Starter Forum Replies Last Post
Shifter Not Shifting Into Park on a 1993 940 that4wdwagon Volvo 240, 740 & 940 4 09-09-2014 06:28 AM
Key stuck in ignition and gear shifter stuck in Park. Obelix Volvo S60 & V60 13 03-01-2014 01:15 AM
1994 940T shifter won't engage park. Rath Volvo 240, 740 & 940 3 07-01-2010 12:03 AM
Transmission shifter staying in park SSN706 Volvo XC90 2 01-25-2010 03:47 AM
Shifter Stuck In 'Park' Position Business_Socks Volvo S60 & V60 1 10-20-2009 01:21 AM
Tags
1995, 1995volvo960stuckinpark, 960, atuck, gear, gearshift, locked, park, part, shift, shifter, stuck, volvo, volvogearshiftstuckinpark, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
