06-02-2011, 05:13 PM
Volvo 960 timing belt replacement
06-02-2011, 07:12 PM
They're easy as pie so nothing to add. Please check your grammar and spelling. "Writting an article..." vs "Writing and article...". Misspelled words harm your credibility.
06-03-2011, 12:04 PM
What year is your 960? Mine is a '93 960 and I am going to venture down this timing belt path real soon. Thanks for the post!
__________________
1993 Volvo 960 Sedan
06-03-2011, 03:08 PM
You should mention that there is a timing mark on each cam shaft and should also be visible in your photos. Differentiate between accessory belt and timing belt, idler pulley and tensioner pulleys for timing and accessory belts. Add more photos with more detail and better lighting. Show some shots as the procedure is performed by the steps.
Ed
06-03-2011, 09:43 PM
06-09-2011, 07:15 AM
Hello,
I'm new here...hope this is a good thread to post this question here.
I am 1993 960 wagon. It needs a timming belt and other bits. They engine was changed slightly 1993 mid year production. The sticker on the enginge is gone. How can I tell which engine it is? The VIN is YV1KW9500P0013890. Thank you mike
06-09-2011, 07:41 AM
Quote:
Originally Posted by 289ERAkit
Hello,
You can check the Volvo site or ask someone at iPd.
Volvo Cars | Community | Your Volvo
06-12-2011, 11:14 PM
My timing mark was in the valley between the teeth. It is a '94.
06-13-2011, 11:54 AM
I've done a couple of these and about the timing marks, they never really lined up for me, so I say just align the crank shaft and mark the cams with some paint. But you are right I should mention them anyways.
Tags
1993, 1997, 2006, 960, 97, belt, change, cost, repair, replaced, replacement, schedule, time, timing, volvo, wagon  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
