Windshield Wiper Switch
Old 10-26-2014, 09:03 PM
jomo60's Avatar
Default Windshield Wiper Switch
Hi,
My wiper switch is just terrible at this point. You literally have to hold it in the correct position to get the wipers moving and good luck finding this correct position. I guess that the contacts on the switch need cleaning. I was wondering if the steering wheel need to come off in order to get to the switch? Can the contacts be cleaned or do I need to replace the switch? Can someone please give instructions on how to remove the switch?
Thank you,
Steven
Old 10-27-2014, 09:40 AM
lev's Avatar
lev
lev is offline
Well, the st. wheel has to come off to get to the switch. Then a replacement is your best bet.
These instructions are for a 960 up to 1995, I haven't done one newer than that: Take off the air bag (two torx screws in the back), disconnect the battery first, wait a few minutes before the bag removal. Secure the clock spring so it doesn't unwind. Pull off the steering wheel but mark its position so it goes back centered and not crooked. Remove the switch, look at it, then decide. A used switch from a junkyard should be cheap, or try ebay.
Old 10-31-2014, 02:00 PM
Blue91SL's Avatar
I have a junkyard with a 95 960 sedan in it, I could pull the switch for you if you're interested.
Old 12-01-2014, 02:14 PM
jomo60's Avatar
I waited until I had time to pull the steering wheel off, which was today. Actually the steering does not have to come off at all. I just took the top trim off from in front of the steering wheel and i was then able to see the two screws which was holding the wiper switch on. The screws easily came off and the switch is out of the car.
I was wondering if anyone has the wiring diagram for that switch?
As always Thanks.
Jomo
Old 12-01-2014, 02:17 PM
jomo60's Avatar
How much for the switch??
rspi
01-11-2014 06:22 PM
Dr.JellyFinger
12-17-2011 02:39 PM
RPMCanes
02-13-2008 05:49 PM
95pimpwagon
01-20-2006 01:09 PM
Mr. T
01-30-2005 03:17 PM
Quick Reply: Windshield Wiper Switch
