1993 850 GLT A/T neutral safety switch location?
I just figured out that this switch is going bad. If I hold the ignition switch in the "start" position and wiggle the gear shift in "park", it will start. Where is the neutral switch located, and how hard is it to replace? I can't see where it is... Thanks!
It' on top of the transmission and Volvo calls it a PNP switch but everyone else will refer to it as the neutral safety switch. If you pull the air cleaner box you should be able to see it.
Instructions on how to replace and pictures !
Volvospeed Volvo Performance Parts Repairs And Turbo Modifications - PNP Switch Replacement (Code TCM 313)
jonqu
08-26-2013 08:31 PM
AnEskimo
06-11-2013 08:15 AM
