1993 volvo 850 blower motor is intermittant
Old 01-18-2017, 10:56 PM
firedrop's Avatar
Default 1993 volvo 850 blower motor is intermittant upon starting car
My blower motor is working intermittently. Sometimes when the car is started, the blower motor works great and hot air is pushed into the cabin. A lot of times the blower motor doesn't start when the car does, and will never turn on, but there will be a small amount of warm air being pushed into the cabin while the car is moving.
I swapped the ECC unit and put a new blower motor in and it's still doing the same thing. (It works randomly when the car is started up, and other times it wont come on.)
also, when it DOESN'T work the AC and REC lights will flash simultaneously after starting the car
sidenote: it's dependant upon when the car turns off if the blower motor will run or not. when the car starts and it works, it works great the entire time i'm driving unless i turn the fan to off then randomly it might not come back on.
OR if the car starts and the blower motor doesn't want to turn on, the AC and REC(or w/e it is) lights will flash simultaneously a few times as the car starts
Old 01-19-2017, 01:34 PM
try going to manual and putting the fan speed on high. If it works then, the problem is in the ballast resistor that regulates the fan speeds (except at full speed the resistor is bypassed)
Old 01-27-2017, 06:14 PM
firedrop's Avatar
it's not that, would be grateful if someone could help :< ty
gearhead
07-07-2014 08:32 PM
Matthew Ruvalcaba
03-16-2014 02:57 AM
rspi
03-18-2013 02:12 PM
mamike55
11-07-2010 05:41 PM
Chupa517
04-03-2009 05:58 PM
Quick Reply: 1993 volvo 850 blower motor is intermittant
