1995 850 t5r slow starting
Over the past few weeks when i start my car is barely wants to turn over for the first few cranks, then it cranks fast enought for the car to start. I thought it was the starter, so i put a new one in and now when i try to start car it just makes one click then nothing. My battery is only 7 months old. Anyone have any ideas, on what i am missing? Any ideas whould be great.
battery
hey Todd get your car electrical system checked as soon as you can. Something is slowly draining your battery OR that 7 month battery just went bad, which could happen and does sometimes.
I once purchased the most expensive battery at Sears for my Dad's Ford Van. It was a high quality piece with a small window to see charge level light, a nice handle, really nice. It looked like something from NASA. Stupid box lasted 4 days. I got my money back and bought a regular green and white INTERSTATE battery for him and that lasted 6 years.
If you have any aftermarket sound system in you car, the amplifiers sometime take a little too much when the car is powered down.
Your battery is run down.
You can just imagine the number of times somebody has posted in any forum this same thing. Usually, they say I replaced the battery, the alternator, and the starter.
My advice is, buy a volt meter. Use jumper cables. Get the car started. Check the voltage running and non-running. Running should be about 14 volts. Not running, once you get the battery charged up, it'll show about 12 volts.
Volt meters are required to fix about half of life's problems.
