1997 850 T5 Vacuum lines
Old 08-21-2008, 03:35 PM
goober4321's Avatar
Default 1997 850 T5 Vacuum lines
Quick question here. 1997 850 T5. On the accordian tube after the MAF there is a vac line (blue) that goes to the TCV on the underside of the accordian hose. There is another nipple on the side of the hose pointing towards the master cylinder that has nothing on it at all. Thinking that this was a dummy nipple I put a hos eon to it and had no problem blowing air through it. Is this nipple normally plugged or is there an actual hose that goes to it?
Old 08-21-2008, 09:19 PM
Default RE: 1997 850 T5 Vacuum lines
Some cars have a hose and others just have a cap on it.
Old 08-22-2008, 08:21 AM
goober4321's Avatar
So if it had a hose where might it go?
Old 08-22-2008, 08:27 AM
I forgetright off hand did you check the diagram under the hood for info yet?
Old 08-22-2008, 05:11 PM
goober4321's Avatar
Does not really show anything. Unless I am missing something
Old 08-22-2008, 05:24 PM
I will look tomorrow on both of my cars and see if it has it. I am thinking it a something with the air pump setup but not sure.
Old 08-23-2008, 07:43 AM
goober4321's Avatar
That would be great if you could.
Old 08-23-2008, 08:09 AM
Both of my cars only have the 1 line.
Old 08-23-2008, 08:55 AM
goober4321's Avatar
So is the other nipple I am talking about plugged with a cap?
Old 08-23-2008, 09:03 AM
Mine doesn't even have the nipple.
Old 08-23-2008, 10:38 AM
goober4321's Avatar
Well I am stumped now.......LOL
Old 08-23-2008, 12:25 PM
Hopefully on Monday I will work on one with it then let you know.
Old 08-23-2008, 12:52 PM
1996850turbo's Avatar
Most likely for an air pump. The hose may have been replaced and I think the replacements include it. Just cap it off for now.
Old 08-23-2008, 07:22 PM
goober4321's Avatar
Ok Tech...that would be great. Here is a pic of the hose/nipple........
[IMG]local://upfiles/16591/68B6C95438EB43F99C01A5DF94713E14.jpg[/IMG]
[IMG]local://upfiles/16591/206525613FC249D59799D5EC2BB72BA0.jpg[/IMG]
Old 08-23-2008, 07:30 PM
I will check on Monday.
Old 08-25-2008, 08:42 PM
goober4321's Avatar
Tech you have any luck yet?
  #17
Old 08-25-2008, 10:08 PM
Sorry we didn't have any of them in the shop today. Hopefully tomorrow.
  #18
Old 08-28-2008, 09:17 PM
I still haven't had one come into work yet.
I will bet it is for the air pump valve located on the back of the engine. Follow the hose from the metal valve to the drivers side strut tower area to the electric valve and see if there is a line missing or trace the other line and see where is goes and if it is attached.
  #19
Old 08-29-2008, 07:15 AM
goober4321's Avatar
Well I have one line the goes from the TCV to the WG. I have another line from the TCV to the accordian hose aft AF. I have one line from the TCV to the tree. I am doing this off of the top of my head. WHere is the air pump on the back of the motor? I have never noticed this before.
  #20
Old 08-29-2008, 06:31 PM
Look for a round metal valve that attaches to a pipe just at the back of the top of the engine. But if you don't have that then it would only be capped. Also check to see if you have an air pump if so it would be under the car on the drivers side. Also you would have a black hose that attaches to the air box lid. It is a bigger hose almost like a heater hose size.
GmacA3
10-10-2009 02:20 PM
j_h_buckley
03-28-2009 09:46 PM
1996850turbo
10-01-2008 10:14 AM
jmana
09-08-2007 04:13 PM
reynrog
01-07-2006 12:36 PM
Quick Reply: 1997 850 T5 Vacuum lines
