1997 Volve 850 GLT Automatic Transmission Problems - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 09-07-2009, 07:19 PM
HRH HRH is offline
Default 1997 Volve 850 GLT Automatic Transmission Problems
I just acquired a 1997 Volvo 850 GLT SW. The Automatic Transmission shifts well at normal acceleration. If you go into passing gear, the tramsission will not change in a timely manner and then it changes with a hard jerk. It appears to be holding back when to the floor starting out or hitting passing gear. May not be a Transmission problem. Any ideas? Thanks, Ron
Old 09-07-2009, 08:04 PM
gilber33's Avatar
Get it serviced and go from there.
Old 09-09-2009, 10:06 AM
Former Sponsor
Could just need to be flushed. What color is the Trans fluid?
Old 09-09-2009, 10:49 AM
JPN's Avatar
JPN JPN is offline
In addition to Groton's suggestion, the normal colour of the fluid for the AW50-42LE should be clear red and must not have burnt smell to it. I would flush the system with the correct fluid (Dexron-III/Mercon) and retrieve fault codes from the TCM (Trans. Control Module); your 850 requires code reader that can access TCM.
Tech, what else could it be?
JPN
Old 09-09-2009, 08:25 PM
HRH HRH is offline
Default Not a Transmission problem, But:
Fluid is nice. I had not driven this car, but very briefly when I posted. Trans is fine. What I think I have is the engine holding back(No CutbacK) under pressure. What does that leave? Turbo, Catalytic Converter, strarving for fuel? The engine feels like it basically slows at 55 Miles an hour & you hit passing gear. Any ideas? I drive Jaguars, not these, but thought I could use a SW. Just tell me where to start. Two scanners showed nothing, but suspect may need one with Volvo software, but I'm not taking it to the Dealer. Thanks for any help. Ron
Old 09-10-2009, 10:23 AM
Former Sponsor
Check to see if you have to much slack in the throttle cable. If it is loose, it might not be opening the throttle all the way, which would make the trans shift late because it does not see a big enough load on the engine.
Thread Thread Starter Forum Replies Last Post
Volve 740 auto transmission reverse selection PhilDunn Volvo 240, 740 & 940 4 03-29-2010 04:33 AM
97 Volvo 850 GLT Automatic Transmission Problems.Help. HRH General Volvo Chat 1 09-07-2009 09:24 PM
volvo 850 glt 1996 automatic problems dock General Volvo Chat 1 05-16-2009 10:29 PM
95 volve 850 wouldnt start please help kozzy00 Volvo 850 4 06-02-2008 08:24 PM
Older volve, new to me, new member Nicholunch New Members Area 2 10-09-2005 02:12 AM
Tags
1997, 850, 97, automatic, burnt, changing, fluid, glt, problems, shifts, slow, smell, t5, transmission, troubleshooting, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
