850 Ball joint clamp bolt removal question
Old 09-08-2006, 02:08 PM
JPN's Avatar
JPN
JPN is offline
Default 850 Ball joint clamp bolt removal question
Dear All,
Hi, I'm writing from Chicago in regard to a question I have about servicing my car.
Here's the 850 I have:
1994 850 Turbo T5 Sedan, automatic transmission, has 140,000 plus miles.
My car has a replaceable front suspension ball joint (attached to the control arm with 3 nuts), and I tried to remove the original unit. I managed to remove the 3 attaching nuts and the clamp nut, but the clamp bolt wouldn't come out no matter what I did. The bolt head is already stripped, and I hit it from the thread-end side with a hammer. It did not want to come out. I then used a chisel & a hammer between the bolt flange and the nuckle, but it did not do any good either.
I believe the clamp bolt is not threaded to the steering nuckle, as it is held by a nut. However, it felt as though it was not a removable bolt, it felt like it was welded onto the nuckle. My last resort would be to use a portable torch and heat it up, but if someone knows more effective method or has had run into the same problem, I appreciate if you could share with me your expertise.
Thanks,
JPN
Old 09-09-2006, 12:03 PM
Default RE: 850 Ball joint clamp bolt removal question
Try the heating method.
The Bolt is rusted solid to the Hub.
Or soak really good and get a Bigger hammer.
Old 09-10-2006, 03:05 AM
JPN's Avatar
JPN
JPN is offline
Dear Mr. Tech,
Thank you very much for taking time to reply, I really appreciate your comment. I'll try the heating method and hopefully I can drive out the bolt, as it is the only thing that's preventing me from installing the new ball joint.
Best regards,
JPN
dpvovo
02-18-2019 07:41 PM
eljefino
07-30-2012 08:14 AM
bostongrun
12-17-2011 01:58 PM
bostongrun
12-15-2011 07:52 AM
schigara
12-03-2009 08:48 AM
Quick Reply: 850 Ball joint clamp bolt removal question
