850 clutch adjustment - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 12-12-2008, 01:49 PM
Default 850 clutch adjustment
Good day everyone. I've ran into a little problem. My clutch pedal is really far off the floor, which causes rough shifts. The clutch is hydraulic and the shop i took my car to says that hydraulic clutches arent adjustable and the only way is to change the slave cylinder. But the thing is i've heard of people adjusting these things, but on different cars. Can anyone help me with any advice. This thing is really pissing me off.
Old 12-13-2008, 10:46 AM
JPN's Avatar
JPN JPN is offline
Default RE: 850 clutch adjustment
The shop is right; hydro clutches are generally not adjustable and should not tempered to adjust. Mechanical cable types are adjustable.
I would try bleeding thesystem for possible trapped air.
JPN
[IMG]local://upfiles/6892/987BED5BABEE4FEB975183E30DC8DE6E.jpg[/IMG]
Old 12-14-2008, 11:26 AM
Psaboic's Avatar
+1 They are not adjustable as far as I am aware
Old 06-29-2009, 12:01 AM
I basically had the same problem. My clutch (pedal) was very soft and found that the slave cylider was leaking. I took it to the shop and got it replaced but it is still having the same problem. It seems like the clutch is only engaging when I press the pedal all the way to the metal. If the mechanic told me he already bled the system, what else cold explain the problem?
Old 06-29-2009, 02:25 AM
850tony's Avatar
the master cylinder having that same issue.
Thread Thread Starter Forum Replies Last Post
S60r, Clutch adjustment? Donzi Volvo S60 & V60 0 11-05-2012 11:27 AM
96 850 Hydraulic Clutch Problem (fluid Leak/no Clutch), Looking for some advice from rrolsbe Volvo 850 9 09-26-2010 09:22 PM
tps adjustment specs? '87 744ti? and afm adjustment? nextproject Volvo 240, 740 & 940 0 11-16-2009 08:04 PM
93 850 Non turbo - New clutch installed but doesnt work. Problem with hydraulic system / clutch fork Dreas Volvo 850 2 12-08-2008 12:41 AM
Clutch adjustment vegedge Volvo 240, 740 & 940 8 04-21-2007 08:40 PM
Tags
1994, 850, adjust, adjustment, bleed, change, clutch, cylinder, floor, ford, hydraulic, pedal, replacement, slave, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
