850 GLT Clutch pedal doesn't come up....
Old 06-21-2006, 01:23 AM
shaver5000's Avatar
Default 850 GLT Clutch pedal doesn't come up....
Hello everyone I just bought a 850 GLT with a five speed it was driving fine untill I parked it, I pushed the clutch pedal down and it just stayed there. I can pull it back up, but it fails to engage the clutch and remains on the floor when presses. I noticed the snap ring on the slave cylinder had been knocked off of its slot. I checked the slave cylider and replaced the snap ring. Then I tried to bleed the clutch for about half an hour today but just air came out, the pedal still sticks to the floor. Can anyone help me?[]
-Thank you everyone
Old 06-21-2006, 01:41 AM
Default RE: 850 GLT Clutch pedal doesn't come up....
Is there a blockage from the Brake fluid resivior to the Slave cylinder?
Old 06-21-2006, 01:44 AM
shaver5000's Avatar
I dont think so because air still comes out of the bleeder valve...
Old 06-21-2006, 01:54 AM
If you keep building up Air thats what leads me to believe there is a restriction.
The fluid should flow from the brake fluid to the slave.
unless the clutch master is bad and pumping air into the system.
KMD
01-08-2015 03:42 PM
tech
02-19-2012 02:07 PM
CarFreak
09-09-2006 11:39 AM
Quick Reply: 850 GLT Clutch pedal doesn't come up....
