850 oil leak top of engine
Old 09-23-2010, 04:05 PM
dhodge's Avatar
Default 850 oil leak top of engine
Looking at buying a 95 850 that needs some work. Here's a pic. can somebody identify what would be causing the oil leak, and what it would cost to repair it. (could do it myself or have it done)
tks.
Dave
Old 09-23-2010, 05:55 PM
VTBricked's Avatar
Could be seal of oil cap or could be PCV-blockage-caused leak. Oil cap seal will be cheap and fast. PCV will be $150 and a few hours if you do it yourself.
Old 09-23-2010, 06:08 PM
Dirty Paws's Avatar
check the cap seal ring, if its hard or cracked wich it probably is, but isnt your only problem.. you need to have to pcv/oil trap replaced, you have to take the intake off and replaced a hose or two.. id almost bet my first born that that car has pressure in the crankcase. and it could come from the back hose just to the left of the pictures you put up lol the hose runs from the pcv box under the intake, in between the intake runners and goes to the top of the valve cover to the left of the oil cap i believe, in that area.
Old 09-23-2010, 06:09 PM
Dirty Paws's Avatar
..... ... BLACK hose... not back sry.
pacificnw2011
09-05-2010 07:42 PM
imon_2nd
07-23-2010 02:50 PM
CassMori
06-19-2009 07:13 PM
SuspTech
01-25-2009 09:54 AM
huzzsaba
02-16-2007 02:34 AM
Quick Reply: 850 oil leak top of engine
