850R immobiliser removal - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 11-22-2008, 08:34 PM
Default 850R immobiliser removal
Hi all
This is my first post here.I have a 96 850R that has just had an engine change and now the immobiliser has prevented starting. I don't have the remote for it, just 2 keys. Is there any way to bypass or remove the immobiliser? I've tried cycling the doors and ignition. No good. There are no fault codes that come up. I'veswapped all ignition components from a runner just in case but no go.
Thanks
Old 11-22-2008, 09:02 PM
Default RE: 850R immobiliser removal
I doubt that is your problem.
Old 11-22-2008, 09:18 PM
Ozark Lee's Avatar
If your hazard light are flashing and it will not crank you can bypass the immobilizer.
Locate relay 210/211 in the lower central electrical unit which is on the inside firewall, just below the fuse box. Remove relay 210/211 and then look at the bottom of the 210 side and locate pins 50e and 50f - they are in the center of that side of the relay. Fashion a jumper wire and jumper the socket positions associated with those two pins. It should start and run fine if that is the problem.
Volvo makes a bypass relay that actually has the jumper wire in a plug in case for the 210 side. I can look up a part number for it if you would like to permanently disable it.
...Lee
Old 11-23-2008, 04:30 AM
It cranks over but no spark. I've checked for power to the coil today and there is when the ignition is switched on. Anything engine related I have changed. Cam, crank, water temp, coil, airflow etc. This is the first time I have had a problem with an engine change. I have 3 t-5's also and 2 had the engine replaced with no dramas.
Old 11-23-2008, 04:57 AM
Could it be the ecu? Bloody thing drove into the workshop before the change!! It had a blown head gasket so I put a new motor in it.
Old 11-23-2008, 07:48 AM
If it was the Immoblizer the motor would not crank.
Is the Cam sensor wiring good?
Is there any codes stored?
Old 11-23-2008, 09:36 PM
Yes they are. I put the ecu in to the other car and it started so rules that out. I put it back in and P0120 came up which did not before. I cleared it but came back again after cranking. I changed the TPS and checked the wiring. Had 0, 5.1 and 5.8V across the 3 wires to the TPS.I have been told that it should only have one 5V supply from the ecu. What do you think? I've checked the loom and there seems to be no damage etc.
Old 11-24-2008, 04:28 PM
Let me see if I can find more info.
Old 12-01-2008, 07:03 AM
Update. No spark or injector pulse!! No idea.
Old 12-01-2008, 09:01 AM
Did you use your flywheel of the one that came with the motor?
Sounds like cam or flywheel sensor signal is missing somehow.
Old 12-01-2008, 04:24 PM
I used the one that came off the motor that was removed.
Old 12-01-2008, 07:20 PM
I've checked the wiring back to the ecu and it's all good. It's got a few mechanics stumped. It should go.
Old 12-02-2008, 06:46 AM
I'm still getting 2 power supplies to the tps. I checked the other car and it only has 1. What would cause this? I've checked the wiring and it's all good.
Old 12-02-2008, 09:02 AM
Possibly.
I would try to ohm the speed and cam sensor and crank the motor over and make sure you are getting readings.
My main wonder is if the flywheel got bent and is messing up the teeth the sensor uses.
Old 12-04-2008, 03:09 AM
It was a straight swap over and then back in. Both sensors are reading.
Old 12-04-2008, 08:51 AM
Something is missing somewhere all grounds connected and good?
  #17
Old 12-05-2008, 07:49 AM
Sure are. My car has only 1 ground under the manifold. One single black wire. It has 2 on top of the motor and 1 on the bellhousing. The other 3 cars have 3 under the manifold. Did they change for the last 850's?
  #18
Old 12-05-2008, 09:45 AM
They might have.
But you should be able to test all of them with a Volvo meter. Connect the positve to the battery and with the ground lead touch all ground connections and make sure you read battery voltage.
Thread Thread Starter Forum Replies Last Post
Immobiliser cut off radio16 Volvo 850 3 10-09-2014 02:28 PM
V50 Immobiliser ..driving me mad...well not driving at all !! timxxx Volvo V50 0 12-21-2009 02:20 PM
engine transplant immobiliser problems bwaarp Volvo V40 5 03-27-2009 04:15 PM
Immobiliser problem 440 scott_mcevoy All Other Volvo's 0 01-14-2006 08:01 PM
Volvo 440 Immobiliser question albini13 All Other Volvo's 3 07-10-2005 10:25 PM
Tags
1994, 210, 850, 96, bypass, immobiliser, immobilizer, injector, pulse, relay, spark, start, turbo, volvo, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
