94 850 trans problem - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 01-28-2010, 10:21 AM
Default 94 850 trans problem
I have a 94 850. When the car is cold, the transmission stays stuck in first gear until the car is driven a few miles. I can drive with the shifter in 3rd gear and the car will shift out of 1st and up to 3rd. Once I have driven a few miles I can put the shifter in Drive and the car shifts through the gears perfectly. I have been searching for a solution online for this problem for about a month. There are many similar problems but not the exact same as mine. I am thinking about changing the transmission fluid, I don't think it will hurt, but I don't know if it will help. I am wondering if it could be a sensor or something. Has anyone had a problem like this, and have they fixed it?
Old 01-29-2010, 10:32 AM
Psaboic's Avatar
I would recommend changing the fluid, but I would definitely check the fluid level right away. It sounds almost like you are low on fluid!
Old 01-29-2010, 12:07 PM
PNP switch will solve this problem easy
Thread Thread Starter Forum Replies Last Post
Need manual trans info from Converse kit, trade auto trans info? nortons General Volvo Chat 0 02-23-2015 12:14 AM
Swapping a 97 auto trans for a 95 trans VolPat Volvo 850 2 06-15-2012 09:06 PM
Automatic Trans leak dripping from trans torque mount small side ded137t5r Volvo 850 15 06-10-2012 08:40 PM
Engine & Trans - 1980 4cyl/4-speed trans (MI) Eric's Hot Rod Shop For Sale / Trade 4 07-14-2011 09:26 AM
'98 XC70 trans swap - pull only the trans? VTBricked Volvo V70 3 11-21-2009 08:50 AM
Tags
1995, 3rd, 850, 94, cold, gear, problems, problen, starts, stays, trans, trasn, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
