95 850 not boosting past 5psi loose ptc grommet
Old 09-20-2010, 01:44 PM
91shelby's Avatar
Default 95 850 not boosting past 5psi loose ptc grommet
my 95 850 is not boosting past 5psi, and it seems i have a rather loose ptc grommet, since that is past the maf and if its sucking in extra air, do you think that could cause it not to boost past 5 because the a/f is slightly off due to the little bit of xtra air?
Old 09-20-2010, 08:24 PM
It is possible. Also check all your intercooler hoses.
Old 09-20-2010, 11:37 PM
91shelby's Avatar
already checked the hoses, its kind of sporadic, though the ptc is barely staying in i need a new grommet,
Old 09-21-2010, 08:22 PM
You are better off replacing the entire hose. Try to find a good used one. Not sure if you can get a grommet seperate
Old 09-22-2010, 10:23 PM
91shelby's Avatar
well it seemed my loose ptc grommet was the cause i fixed and shoved it back in the hole with some rtv for now, and it runs like a champ again
Old 09-23-2010, 07:45 PM
Glad all is good now.
Old 09-25-2010, 10:03 PM
91shelby's Avatar
it was ok now its doing it again, i cant detect an leaks in the IC or around the ptc, is it possible the spring for the wastegate is going..?
Old 09-25-2010, 10:39 PM
Maybe but if it was not working at all then you would have full boost.
Also check where the waste gate arm attaches. If the arm it attaches to is raised any that might be your problem.
Old 09-25-2010, 11:55 PM
91shelby's Avatar
what do you mean by raised? and how would this come out of the blue?
Old 09-26-2010, 07:10 AM
They will slightly move over time and then do this.
Where the red arrow is pointing is where you need to check. You can also see in the pic when it is raised like that it does not seal.
Old 09-26-2010, 07:25 AM
ibified's Avatar
holy crap that turbo is coked up....just sayin!
Old 09-26-2010, 01:41 PM
91shelby's Avatar
if that is the case how to i remedy it?
Old 09-26-2010, 07:43 PM
91shelby's Avatar
occaisionally will boost to 6 but only in the higher rpms...
Old 09-26-2010, 07:53 PM
Bobec's Avatar
My wife and I carry guns because police officers are too heavy.
that cracks me up, thanks for the laugh.
Old 09-26-2010, 07:58 PM
Bobec's Avatar
did you look at the IAC hoses? Right after I put silicone on mine I floored it and blew out one (the top, IAC to vacuum tree). They see the pressure too and they have no reinforcing. I sent my bad hose to stylinmotors and they said they'd add a silicone replacement to their product line.
Old 09-26-2010, 08:38 PM
You carefully tap the arm back down till it seals.
  #17
Old 09-26-2010, 08:44 PM
91shelby's Avatar
IAC hoses look ok, i actually just replaced the upper IAC hose and the lower seems ok, i plan to upgrade those as well when i can, will let you know on the wastegate arm
  #18
Old 09-27-2010, 10:08 PM
91shelby's Avatar
well today it missed a few times, can a failing camshaft positioning sensor cause this..?
  #19
Old 09-28-2010, 07:43 PM
Usually not. All tune up stuff new?
  #20
Old 09-28-2010, 08:18 PM
91shelby's Avatar
yeah new oem bosch wires cap rotor, autolite platinum Iridium plugs, and the wastegate arm is fine im going to go thru all the lines again tonight
Quick Reply: 95 850 not boosting past 5psi loose ptc grommet
