95 850 OBD-II connector
+1 Both 1994 and 1995 Volvo 850's are both OBDI and OBDII compliant. 1996 is that date that all cars had to be OBDII compliant, but some models were before that. Just like that picture shows, that's where it is. I have gotten codes pulled many times using an OBDII diagnostics tool.
Who do you think Ford learned how to do turbocharging correctly from??
And... I guess you learn something new every day... I never realized that some of the older 850s had OBD-II plugs on them. I don't see THAT many older ones. Now, I know VWs have used them since about 1993 (though they only have the 16- pin connector, but won't communicate with OBD-II readers or display OBD-II codes. They only show pre- OBD-II VAG codes until 1995, when some of them started actually being OBD-II compliant.
And the OBDII thing isn't very common amongs pre 1996 cars. It's pretty comical though when I go to an Autozone and tell them I need my codes pulled and they try to convince me that it won't work. God, total face palm. They don't say much though when they plug it in and it works. Lawlz.
There was 2 reasons I hesitated purchasing my Yellow 850 R. I did not like the window switches being in the center console and the fact that I did not know it was OBD-II compliant.
I was very relieved that it had the OBD-II connector. I'm working on the door window switch. I plan to mod mine soon.
#19
#20
