ABS module- Repair or Replace?
Old 11-13-2006, 05:21 PM
Greenrino's Avatar
Default ABS module- Repair or Replace?
I have a suspected bad ABS module and want to know if there is any direct way to test the module to ensure its bad. The replacement is over $300. I found a place that claims they rebuild the module for $99.00 and give a 5yr waranty, does anybody know if this is a real repair? This is the website that claims they fix them www.autoecu.com.
Old 11-13-2006, 11:39 PM
robert213's Avatar
Default RE: ABS module- Repair or Replace?
r213faq rebuilding ABS module
Nearly all Volvo owners recommend...
http://home.earthlink.net/~vicrocha
his e-mail is: vicrocha@earthlink.net
vicrocha@earthlink.net?subject=Volvo%20ABS%20Control%20Unit%20Repair
Old 11-13-2006, 11:41 PM
JPN's Avatar
JPN
JPN is offline
Greetings from Chicagoland.
You wouldn't want to spend $300 for an ABS module, it's overpriced as you say. In my opinion, 850's ABS module was a defective unit and should have been a factory recall item, because so many people are having the same problem.
I don't know if there is a direct way to test it. Since the problem is common, it could have been a poor soldering, faulty connections, defective solid-state devices (IC, LSI, diode, transistor, etc...) or simply a poor circuit board design. Unless you are an electronic wiz or know someone in the electronic engineering department, you might end up damaging it further with static electricity.
Judging from advice by experts on this board, rebuilt unit seems like the best option, and it seems to run about $100 or so. That's what I would do.
Good luck,
JPN
PS: The guy in the cartoon looks like GWB.
Old 11-14-2006, 11:42 AM
Greenrino's Avatar
Thanks for the info, i will be sending it in.
J
Old 11-14-2006, 09:19 PM
Greenrino,
What symptoms are you noticing with your brakes? My ABS light will come on every now and then when driving and stay on until I get home and park. 1995 850 Turbo
SD
Old 11-15-2006, 09:14 PM
Greenrino's Avatar
The ABS light just comes on sometimes then the tracs off light. Then it will go away. Sometimes it will last for a couple of days sometimes only until next startup. From what i have read and seen on the forum the module is prone to shorting out. I am sending mine in for repair (dont want to spend $300 for a new one)
J
JohnAT
08-04-2022 12:02 PM
mrpyromaniac
05-25-2013 09:36 PM
Pej
07-09-2011 08:32 AM
volvoexpert
07-14-2009 02:45 PM
air force rascal
06-22-2009 01:38 PM
Quick Reply: ABS module- Repair or Replace?
