Automatic Transmission Fluid flush
RE: Automatic Transmission Fluid flush
I'm trying to put the right level of fluid but when check the Level when it's cold, it looks like i'm missing just a bit of fluid. But when I check it when it's hot, there's no oil on the stick and I keep adding and adding. I tought that the level should have higher when it's hot.
Yes, while it's running. When they say cold, if the car haven't been running for 24h and
I start the engine and check it right away, is it ok? (These days, the temperature is arround 0 celsius).
I think that it might have been an accumulation of oil on the pipe's walls because now, even cold, there's no oil on my stick. I'll continu to add some more until I see something.
