Automatic Transmission Fluid Question
What is the cheapest quality synthetic automatic transmission fluid that meets or exceeds Volvo fluid our cars come with. Basically i dont want to spend $18 per quart for Volvo fluid. However i want to put something that is as good and cheaper.
Here are a few i have read about.......
1) Valvoline Max ATF
2) Mobil 1 ATF
3) Amsoil ATF
Would i even be able to use Honda ATF? I have some leftover from the Honda i sold
2) Mobil 1 ATF
3) Amsoil ATF
RE: Automatic Transmission Fluid Question
Hi,
I'm not sure if synthetic gearbox fluid provides any benefit, it may or may not. I've never used them so I cannot say it's good or bad.
As to the fluid type, always follow the owner's manual or ask at Volvo dealer. But since your cars is 850, you need Dexron-III/Mercon. The owner's manual maycall forDexron-IIE, but IIE has been superseded by III. Also, correct fluid level is just as important as the type. Do not overfill/underfill.
I use Coastal regular fluid, about $2 a bottle.
Good luck,
JPN
Good luck,
JPN
I went to Advance Auto Parts and bought their branded Dexron-III/Mercon fluid in the gallon containers. I bought three gallons plus two quarts. I think their's was $10 a gallon. My reasoning?
Advance Auto Parts has Havoline make all of their lubricants. Thus, I know it meets specifications and is from a reputable manufacturer. Plus, I plan on changing it every 18-20k, so at $35 per flush, it's a good deal. - AB
The $18 per quart ATF from your Volvo dealership is Mobil 3099 designed for 5-speed automatic transmissions used in 1999 and newer model years. Even though it can be used in transmissions for older model years -- it is not synthetic. it is too expensive.
I use regular Valvoline Dexron III -- same as used by local Volvo dealership.
Many folks prefer Mobil - 1 ATF and AMSOIL ATF.
Don't power flush. Let the automatice transmission flush itself. Some folks prefer the transmission flush kit from IPD -- other folks make their own flush kit from parts at the local hardware store.
http://www.ipdusa.com/ProductsCat.as...549&RootID=629
http://www.ipdusa.com/pdf/PI-290TrannyFlushKit.pdf
Here are procedures...
http://www.matthewsvolvosite.com/cha...pic.php?t=8767
http://www.matthewsvolvosite.com/cha...pic.php?t=8742
ORIGINAL: volvo4mula
in my shop we use Amsoil ATF. The stuff is very good and since you only get about 3 quarts out of a drain and fill it's good to have quality fluid.
On a side, what fluid changing intervals are you following for your trans?
ORIGINAL: B1mmer
We're talking doing a true flush, not just a drain. The manual states to change it every 20k. - AB
The drain plug is not that hard to find. It's on the drivers side and it's a big drain plug. You can't miss it. What I did with my V70 was jack it up and put it on jack stands with the wheels about 2 inches off the ground. Then I drained and refilled three times starting it and running it through all the gears for about 30 second in each gear. Leave the drain plug just finger tight until the final fill. On the 850 it's been just drained and filled every 20K. I did not know the history on the V70 so that's why I did it that way. I used Penzoil Dexron III.
Hello again,
The following may be of a reference to you:
http://volvospeed.com/Repair/Transflush.php
The drain plug is on the bottom of the gearbox, facing sideway. You can't really miss it.
I personally think flushing with a kit would be easier than draining, driving, and draining again. As to the service interval, I personally do it at every 30,000 miles or so. No scientific reasons behind it, it's just what I feel comfortable with.
Good luck.
JPN
Good luck.
JPN
Yes, BUT NOT ALL VOLVO TRANSMISSIONS ARE AISIN WARNER'S. Some are GM transmissions. For the sake of avoiding transmission damage make sure to check your owners manual for the exact Volvo spec and then match it up with something on the shelf. Yes, the Aisin Warner's spec is the same as Toyota's Type T-IV, as is Mobil 3309. The reason Valvoline MaxLife (what I have been using for my '02 S-60) works is because it is compatible with the specific fluid spec listed in my owners manual, but the 1999-2005 S-80's all had GM's 4T65E auto transmission in them, so that fluid is a different spec than what goes in the Aisin Warner. One thing really nice about the Valvoline MaxLife is they somehow managed to make it meet lots of different specs, but you still have to do your homework.
theone29
09-30-2009 11:11 PM
Francis
09-26-2008 02:45 PM
