A/C Compressor Clutch Reshimming
Old 07-09-2006, 01:59 AM
Default A/C Compressor Clutch Reshimming
Once compressor is off set it like the following pic and remove the 10mm screw in the middle of the pulley.
Then carefully remove the outer part of the Clutch.(There is a special tool which I didn't have I used to screw drivers but be careful)
Then either the shims will come out with the outer peice like mine did or they will be sitting on the shaft once the outer part is removed.
If you look closely the washers/shims are different thicknesses. You will need to Measure the thickness and then find one a little thinner and reinstall and check the Gap between the outer and inner part of the clutch.
I will have to find out the exact specs but I believe it needs to be .016 Cannot be more than .020.
Use a fueller gauge to measure the gap.
Hopefully this helps.
If you have any questions feel free to ask.
Compressor Specs: Gap should be between .3MM(.012Inches) and .5MM(.020Inches)
.6mm(.024) should not fit in at all
Old 07-20-2006, 10:45 PM
B1mmer's Avatar
Default RE: A/C Compressor Clutch Reshimming
Tech... excellent post. Just to clarify, I should be measuring between the clutch surfaces, and I'm guessing the gap will be bigger than the spec (due to clutch wear) thus, going with a thinner shim will bring it back into spec?
Wear would I get the correct shims? Thanks - AB
Old 07-21-2006, 12:24 AM
Yes you are correct.
I used small washers that were close to the size of the shims.
Volvo only sells 4 shims for it.
If I needed to go thinner on the washer I rubbed it on a file to thin it out.
Old 12-29-2006, 12:06 PM
axelm's Avatar
Any spec on the material the washer has to be made of? I imagine it has to been stainless steel, but any other spec?
Old 12-30-2006, 12:02 AM
Not that I have.
Most of the time you just need to remove one of the one that are already there to bring it into specs.
Old 03-21-2008, 01:33 PM
xpiecemealx's Avatar
So would this be my problem if my car doesnt even do anything when I turn the ac on? No engine bogging down or no parts turning. Nothing!
Old 03-21-2008, 06:37 PM
Does the center of the compressor spin?
Do you have power to the low pressure switch?
Old 12-28-2008, 02:18 PM
Rosew6211's Avatar
A 30 minute job put my 96 850 AC clutch back in order. I had heard that if AC is on, compressor wheel is turning but will not engage, I could take a broom stick and lightly push it against clutch plate wth motor running and AC on at lowest temperature setting. If clutch plate kicks in and engages the compressor, them shimming is needed hold plate clearances within spects. I jacked up the right front, put in a safety jack stand,and working from underneath, I checked the clearance. It was 30 thousands over spects. With Simple Green and water ,I cleaned the clutch face and blew it dry. Working from underneath(which gives access to the clutch) and using a screwdriver to lift the existing spacing tabs, I inserted a small, bread bag tie clip size and thickness, shim under each tab and secured them in place with epoxy. Some use crazy glue. This is hold shims in place when clutch is not engaged. A recheck showed spect. clearance and the AC works perfectly. This may not be Mfg's recommendations; however, it worked for me and saved dismantling the clutch assembly.
Old 06-30-2009, 04:33 PM
jimboy's Avatar
Default A/C intermittent
would this work the same for a 2005 v50? The A/C cuts out intermittently. If I tap the compressor with a wrench it will start spinning again. Also can I do this on the vehicle, removing belts first of course.
Old 06-30-2009, 08:44 PM
It works exactly the same way. On the 05 you should be able to unscrew it from the oil pan and leave all the lines connected.
Old 07-01-2009, 10:51 AM
jimboy's Avatar
Default a/c compressor
Worked like a charm. Mine had 3 shims. I removed 2 and it is working great. I had to use a puller to remove it and the outside looked slightly different with 2 belt pulleys. Thanks for saving me hundreds of dollars!
Old 07-02-2009, 04:51 PM
volio09's Avatar
Hey Jimboy, could you please tell me what type clutch puller you used and where you got it? I'm desperately trying to pry mine off today and it doesn't come off... I have 2004.5 T5 similarly than you... Thanks in advance!
Old 07-03-2009, 09:02 AM
I use a small one like the one in the picture.
Old 07-10-2009, 07:42 PM
worldbound4now's Avatar
My 2001 V70 compressor works flawlessly until today, when we hit 107. Now it kicks off and won't kick back on until the unit has had a few minutes to cool. Is this a shim issue or is the unit overheating, causing some safety device to disengage the clutch.
Thank you!
Old 07-10-2009, 08:16 PM
850tony's Avatar
prolly overheating....
Old 07-11-2009, 08:46 PM
So, if overheating, how is this fixed. Shop service with coolant and oil change or something else? An A/C that doesn't work when it's hot out is kinda foolish. Thank you for the help.
  #17
Old 07-11-2009, 09:17 PM
850tony's Avatar
prolly an ac change...
  #18
Old 07-12-2009, 02:06 AM
blackbrick's Avatar
  #19
Old 07-14-2009, 04:14 PM
Originally Posted by blackbrick
Thanks blackbrick. The information was insightful. Looks like I have some tinkerig to do and budgeting to do for some AC work in the near future.
  #20
Old 07-18-2009, 02:43 PM
artic_fox's Avatar
More AC A/C Compressor, Low Sensor, High Sensor Pics at: https://volvoforums.com/forum/album.php?albumid=156
Quick Reply: A/C Compressor Clutch Reshimming
