A/C Compressor Clutch Reshimming
Old 08-04-2016, 08:19 AM
mtroxel's Avatar
Originally Posted by Shappy
Thanks for the reply! However I don't know what "tip ties" are, and what sort of c-clips? I would like to try them. Thanks!
To be honest, trying various nylon items until you get the right gap seems like more work, and is less reliable, than pulling the clutch off and removing shims. Just measure the gap before you pull the clutch, measure the shims inside there and remove till you know you'll be back to .2mm - .5mm. Bolt it back together. It might take you an hour.
  #82
Old 08-07-2016, 02:45 AM
boxpin's Avatar
Not when you can have the entire job done in 20 minutes. Honestly, it just needs to be closer. Its not rocket science. When they stop working they are right on the edge of too big a gap. Any movement to get that gap smaller will fix the clutch. Just make the gap smaller with whatever method that floats your boat. It will work, just make the gap smaller.
  #83
Old 08-27-2016, 07:23 PM
mrcharlie's Avatar
Just got my a/c cooling again today, although I used the quickie zip tie method. But I saw it here previously on this excellent forum. Thanks to all.
  #84
Old 07-13-2017, 12:43 PM
volvolover59's Avatar
Default does this apply to a 2006 c70??
I have a 2006 that is acting up the ac blows cold until the throttle is raised and then it's all over for the cold air. can my pulley be shimmed in this fashion? It seems that all of these posts are referencing older models
mureste
07-30-2008 08:08 PM
volksnut
08-05-2007 01:52 PM
hxcboatcaptain
09-08-2006 02:16 PM
mrbyrd
05-31-2006 09:43 PM
camera cart
06-03-2005 03:45 PM
Quick Reply: A/C Compressor Clutch Reshimming
