A/C relay location on 1993 850
Old 07-12-2009, 03:48 PM
engineeringnerd's Avatar
Default A/C relay location on 1993 850
I'm trying to find where the a/c relay is on a 1993 850. I've looked next to the fuse box (removed 4 screws), not there. Anybody know exactly where it is located?
Old 07-12-2009, 05:54 PM
Turconator's Avatar
Behind the glove compartment. You have to take the glove compartment off. Then behind that there should be a relay kind of in the centrel maybe offset toward the drivers side. It should be black with green lettering and numbers. That's what mine looked like.
Old 07-12-2009, 06:05 PM
Well, we did find that, however, the replacement relay had 5 prongs, and was green, as well as slightly smaller. Perhaps we got the wrong relay? We purchased it off of RockAuto.com from the volvo 850 AC category.
Old 11-11-2009, 06:31 PM
bdruff's Avatar
engineeringnerd, was it the right relay and how much was it? Also, did by chance the bad relay cause your cig. lighter to not work?
Old 11-11-2009, 09:06 PM
mhutchens's Avatar
The original relay is a solid state way to complicated thing. The replacement relay is a pretty much standard SPDT relay that you can get at any auto parts store. Keep in mind most auto relays are SPST relay.
Old 11-11-2009, 09:13 PM
Try not to group problems together. You have 2 problems, not 1. Unless they are on the same blown fuse.
Old 11-12-2009, 11:36 AM
bdruff's Avatar
Sorry, I am deciding on whether or not to buy this car. I was just trying to figure out if they might be related.
sleech
01-25-2020 05:07 PM
rspi
06-17-2013 09:09 PM
nuthinbutmacs
10-08-2011 04:20 PM
dads 740 turbo
10-24-2008 06:54 PM
steves96
11-14-2004 11:40 PM
Quick Reply: A/C relay location on 1993 850
