Can I use a 16t turbine on 15g cartridge?
Old 06-07-2013, 12:03 AM
Chrispy_T's Avatar
Default Can I use a 16t turbine on 15g cartridge?
I have a totally trashed 16t with a good compressor side. Can they be interchanged with my stock 15g? I would really hate to have to spend more money than necessary. I'm eyeballing ebay for cheap deals on a cartridge.
Old 06-07-2013, 08:06 AM
boxpin's Avatar
It will not work. The 15G is a flat back and the 16T is a super back.
Flatback compressor wheels:
TD04-9B
TD04-11B
TD04-13C
TD04-11G
TD04-12T
TD04-13G
TD04-15G
Superback compressor wheels:
TD04-13T-4
TD04-13T-6
TD04-15T
TD04-16T
TD04-18T
TD04-19T
Old 06-07-2013, 10:33 AM
Chrispy_T's Avatar
I found this write up on ClubRoadster this morning. I think I may try it. The reason I want to convert my existing turbo is that the one I bought has be destroyed on the exhaust side. The shaft split at the bearing and the compressor side bearing seized to the shaft. The compressor was undamaged since, surprisingly enough, the shaft had absolutely no play and still spun freely. The exhaut side ground away at the housing a little and ground a third of an inch into the cartridge. I don't think the angle outlet housing is salvageable. That sucks alot.
Old 06-09-2013, 12:35 AM
Chrispy_T's Avatar
Well, I have found the information I was looking for so I will leave some information for anyone else who wants to give this a swing. The 15g bearing housing has an inset place for the compressor which is ~57mm across. A 16t compressor has an extruder diameter of ~56mm which is still small enough to fit the housing without lathing it out. Since TD04HL housings are technically interchangeable, the factor exhaust side can be left on the car and the compressor wheel and housing can be changed without replacing anything else aside from the backing plate under the compressor and the oil seal inside it. All that is necessary to do the conversion is to buy a turboback rebuild kit to rebuild the flatback housing. I will do a build video and post a new thread on the conversion once I have the kit and time to do so. In the mean time, can anyone point me to the cheapest ECU flash that will remove the boost limit? It's driving me nuts when I smash the throttle and it cuts out around 14PSI.
rspi
03-09-2016 08:17 AM
Chrispy_T
06-19-2013 02:15 AM
chax
12-21-2011 05:00 PM
jessica
07-06-2010 12:53 AM
anubyss
01-01-2006 06:29 PM
Quick Reply: Can I use a 16t turbine on 15g cartridge?
