Car won't start, battery fine, hazard lights flashing?!?
Old 05-23-2008, 02:38 PM
erickfredrick's Avatar
Default Car won't start, battery fine, hazard lights flashing?!?
Hi again!!
1996 850 Turbo
Car would not start a few days ago, so I jumped it and it was fine...nothing was left on.
Today the car will not start again, but jumping did not help. The car has been completely fine since the last time it would not start.
When I turned the key to start the car, it would not start, but the hazard lights started flashing, WITHOUT the hazard light button being depressed.
The battery tests fine.
I don't know much about cars. Any ideas?
Erick
Old 05-23-2008, 06:10 PM
Default RE: Car won't start, battery fine, hazard lights flashing?!?
The alarm was triggered.
Old 05-23-2008, 07:58 PM
I suppose that would explain the flashing red light in the dash... So what do I do about it, and how do I prevent it in the future? Thanks!
Erick
Old 05-23-2008, 08:18 PM
Lock and unlock the car and it should reset the alarm.
It must not have unlocked all the way before.
Old 05-23-2008, 08:44 PM
What a relief. thankyou so much!!
Erick
Old 05-23-2008, 08:47 PM
No problem anytime.
Old 05-24-2008, 01:41 AM
Quick Brick's Avatar
Hey now,
I had the "alarm" problem once when on a date .
I used the fob to lock the doors but used the key on the passenger side, the chivalry thing, and as soon as I turned the key the lights and horn started going and all I could do was laugh [sm=smiley36.gif]. If it was going to happen, it was going to happen then. Date and all.
I had to go to the drivers side and use the key in the door to turn the alarm off then go back for a second try at the door for my date. Giggling all the way .
Glad it all worked out for you and didn't cost anything to fix.
[sm=icon_cheers.gif]
Old 05-24-2008, 05:22 AM
JPN's Avatar
JPN
JPN is offline
I believe it was part of Volvo's design philosophy to get people's attention, be it the woman or the car.
Swedish way of romance.....
JPN
Old 05-24-2008, 12:10 PM
Hey now JPN,
[sm=icon_rofl.gif]
It did, however, turn out to be a bowchickawawa [sm=happy046.gif][sm=wootwoot.gif]kinda night [sm=smiley20.gif].
Still glad for you,Erickfredrick.
Old 09-10-2011, 06:14 PM
Vjc's Avatar
Vjc
Vjc is offline
Replaced Volvo 850 95" w/ new battery..would not start. No spark in ignition coil..replaced coil, still will not start. checked distributor wires etc.good. Is this a computer glitch? Still no spark in the new coil..checked all fuses..good.
Old 09-10-2011, 07:26 PM
Search a few things about the cam sensor.
Old 02-03-2015, 05:42 PM
joegal777's Avatar
This information just saved me a tow. This happened to me 10 years ago but I forgot how to fix it. Like Wax on Wax off, it was Lock off lock on, car starts!
Bingo!
Thanks
Old 11-01-2015, 12:38 PM
alecw81's Avatar
Had this same thing happen to me today with my 98 S70 GLT.
The car sat for about a year, jumped, drove 2 hours, ran fine.
Then I parked it at my new home, and it sat for another 3-4 months or so.
Today I picked up a new battery at Costco (HG48), that fits perfectly.
As soon as I connected both terminals, the alarm went off, and nothing will shut it up.
I have the key fobs, but both of them have dead , and I'm assuming that simply putting in new batteries won't be all it takes right?
Old 11-01-2015, 04:35 PM
alecw81's Avatar
I'm an idiot.
Let it rest for a few hours, popped the hood, locked the doors, hooked up the battery.
Alarm sounded again, but simply turning the key in the drivers door turned it off. Car started, all good in the hood.
Old 10-13-2017, 09:10 PM
Kelly Crowley's Avatar
Default Car won't start flashers flashing...
Battery is fine. My boyfriend had reached through the back door window to open it and let his dog out. When I got in, turned the key, nothing worked but the flashers. Read this post. Got out. Locked the car and then unlocked it. Got in. Turned the key... No flashers and the car started. Thank you for this post!
Old 11-25-2017, 11:45 AM
Kimberly Davis's Avatar
Default Thank you
This car is almost 20 years old and when this happened I thought the car was dead forever...but I locked the door and unlocked....and it worked just fine.....thanks so much for your help!
puxnstx
06-04-2020 06:28 PM
sparky618
06-09-2011 08:30 AM
mrdude888
12-17-2010 06:56 AM
chrystald423
03-27-2010 08:05 AM
Volvaman
04-27-2008 03:14 PM
Quick Reply: Car won't start, battery fine, hazard lights flashing?!?
