Headlights Won't Turn Off 96 850
Have a very frustrating problem with a 96 850 sedan. The headlights and running lights stay on after the ignition is turned off and the light switch is on off. I thought it was a defective headlight relay and replaced it with an original part, but the problem continued. I tried unplugging the headlight switch, ignition switch, fog light relay and the blinker/flasher switch, but the headlights stayed on!!! Unplugging the main headlight relay turned off the headlights, but the running lights still stayed on. The only action that turns all the lights off is unhooking the batthery! HELP, I'm really stymied and frustrated!
Just a WAG but i would suspect the electrical part of the ignition switch.. Someone with access to a schematic is going to have to trace it down
Any other suggestions would he helpful
Found the doggone problem !!!
Problem solved...Pulling the headlight relay made the headlights go off, but not the running lights...the harness from the main light switch went into the dash, thru the firewall, into the main power distribution box under the left rear of hood, where it went to relays, then to fuses, and on to the lights. Pulling the fuses made the lights go out, so I figured the short was between the main light swictch and the power dist. box. I took off the top dash cover (a grueling task!) removed the instrument cluster, and discovered that some genius who had worked on the car before, had tucked the harness between the cluster and the sharp metal edge of the interior dash frame, which eventually sawed thru the insulation and grounded the wires from the switch... I freed the harness, taped off each bare wire, lights are off, and problem solved! Thanks for the suggestions everyone!
I have the same problem. The headlights and running lights don't go off. It is somewhat intermittant, but more intermittant than not. Car is "new to me", so it is possible that someone has been under the dash, I'll give that a try. In my search I noticed that someone on the UK board had the same problem posted, no significant responses. I think I will try banging on the dash first.
