Dashboard Instruments
Hi there,
I'm new to the forum, so Hello
I have a 1996 volvo 850 AWD.
Yesterday when i turned it on none of the dashboard instruments worked.
They haven't played up before, I've just had a few electrical faults with the cruise control and ABS.
I've searched this issue and there is a precious post about it, although the fault was never resolved..
Any Advice..?
Cheers
Any Advice..?
Cheers
does the car run?
I had a problem like this with mine, the no dash light thing. In my case, it turned out to be the dimmer switch - bad.
If it's the same on your car, its the sliding (left to right) rheostat deal near the headlight switch..
I had a problem with the positive battery cable as well. It makes a nasty 90 degree bend that corrodes out over time... also under the fuse box where the main power line comes in...
