dave wammy walmsley
dave wammy walmsley
Hello - any advise on speedo being intermittent ? I fitted another dashboard and connecting cables,but the speedo is still the same ? Help - Dave. (850 Estate 1996 - petrol - 2.5cc)
Last edited by Dave Wammy Walmsley; 03-12-2017 at 05:23 AM. Reason: further explinations to problem.
could be the speed sensor or the ABS controller. Any other clues ie does the ABS or Tracs light blink or illuminate from time to time? ABS controller boards can develop cracks in the solder joints leading to an intermittant fail. Speed sensors can get gunked up, particularly if you recently did work on the hub or axle and a cleaning may help.
dave wammy walmsley
Hello - thank you for your reply. The Dashboard ABS indicator light is always 'ON' even though I have changed all the wiring to each of the wheels. I'm at a loss - help - dave. www.wammy-uk.com
