diagnostic and OBD-2
Old 12-04-2005, 04:00 PM
tomservo's Avatar
Default diagnostic and OBD-2
So I have a '95 turbo and both diagnostic systems. My question is are both as good as each other? I pulled a couple fuel codes from the engine bay, I don't have the scan tool, but it doesn't seem to work in the 6th socket. I haven't tried the others.
Side note, one codes was a front knock sensor, the manual says I need to remove the intake manifold, is this true?
Old 12-04-2005, 04:12 PM
Default RE: diagnostic and OBD-2
You might be able to get to them without removing the intake.
The only difference between the OBDI and OBDII is if you had a decent scanner you can monitor different things with it.
Dads850
03-05-2009 03:18 PM
chachouu
12-06-2008 04:36 PM
pittpan2005
03-16-2008 10:23 AM
emek
12-17-2007 10:57 AM
Quick Reply: diagnostic and OBD-2
