Engine coolant temperature sensor
RE: Engine coolant temperature sensor
No problem. Be careful taking the torx screws out. They are very easy to strip. Make sure you use a good torx bit that is exactly the right size. When I did mine, I did not put the torx screws back in. I went to NAPA and bought regular hex bolts to put in.
ORIGINAL: JimKW
If it improvesthe situation I always replace the Torx screws too.
ORIGINAL: JimKW
Yes, I also left the battery connected but made sure the ignition was off. The connecter might be tough to separate, as it has been together through thousands of heat cycles. Just take your time and work it loose. A very small flat blade screwdriver might help. Just curious, are you getting the infamous 1-2-3 c ode and check engine light?
#17
I may need to replace this part too. My radiator fan is not coming on and I am still trying to diagnose whether it is the ECT sensor or the fan relay or the fan itself. In looking for this part at AutoZone, their information describes it as being in a different location
"Under hood, center, front engine area, mounted on lower front passenger side of engine."
Which would be the one I need to replace? I can see something in that location that resembles the one at the thermostat housing. It is the same as the one offered for auction here http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
Thanks,
Tracy
Thanks,
Tracy
#19
Well, two reasons I can think of. One is just profit as they make more if they talk you into a coolant flush. The other is that they may think that if you're having a sensor replaced it's just good insurance to have fresh fluid in the cooling system and most people aren't nearly as "religious" about flushing out their cooling systems as they are about changing oil Most cooling systems are overdue for a change.
#20
