Experiences with Seafoam Spray?
Luke,
what problem are you trying to solve? The only concern I've heard is on how the spray gets into the intake - if you are going to suck in the spray via an upstream vacuum line, you will risk messing up the MAF. A better deal would be to use CRC MAF cleaner on the MAF then use carb cleaner products on the idle air valve. There's also a great recent post on how to clean your throttle body as well.
AnEskimo
10-09-2010 12:13 PM
xrturbo
06-09-2007 09:29 AM
