General Consensus on K&N Flat Filters
Old 05-23-2016, 03:33 PM
Luke Woessner's Avatar
Default General Consensus on K&N Flat Filters
What is the general consensus on K&N Flat Filters? Are they worth the extra money? How does the engine respond?
(2.4L T5 N/a Stock)
Old 05-23-2016, 08:07 PM
ES6T's Avatar
You won't notice anything.
Old 05-23-2016, 08:53 PM
97-850Wagen's Avatar
Personally, I don't buy into the hype of more power from these types of filters. However, that said, my thoughts on them are that they are worth a bit more $ in the short run to save money in the long run as they are reusable. And with that said, I don't personally like/recommend the K&N style filters and would prefer to use a dry flow filter that doesn't require oiling after cleaning (to eliminate the remote possibility of contaminating the MAF sensor with oil from over oiling). If I could find one that fit my car, I'd be all over Green Filters brand high flow filters in a heartbeat, however they seem to have discontinued making them for the 850 (model 2148) and when found they are over $100 online for NOS. Also kind of partial to them since its a local company...Tried contacting them a few months back to see if they had any in stock or if it was another part number superseding this one, to no avail and no answer in return...
Old 05-23-2016, 10:39 PM
I tried both on my 850T. Didn't notice any difference - power, noise all the same. I'm now back to OEM Mann paper filters.
Old 05-26-2016, 04:40 PM
louiebay's Avatar
U still have to take out and clean the K&N filter and u need to use the right oil spray. Then you can't just put it back in the car after cleaning and spraying, u have to let it dry and that takes another 3 to 4 hours. If it is not dry after cleaning, your engine sucks that oil into the intake.
I had K&N filters on my other cars and unless you air filter box is modified(drilled)holes for the deep throaty noise) there is no difference in performance. It was getting to be a pain cleaning them every 4 months or so.
When I change out the filters I can see the reason why I am changing them. Noticeable dirt and dust. With K&N, since they are colored (Dark Red) they become dark in color days after you clean them. So you have to keep track and also a reminder on cleaning them.
IMO...Thumbs down from me
Old 05-26-2016, 04:57 PM
tryingbe's Avatar
Paper filter would have more filter surface area than k&n filter, more surface area means more space for air to thru.
brickrunner
05-06-2014 12:16 PM
alam
01-01-2014 07:58 PM
movistardave
01-20-2013 12:07 PM
Yemelianare
01-16-2012 01:43 PM
robrike
11-17-2007 01:05 AM
Quick Reply: General Consensus on K&N Flat Filters
