Grinding noise behind headlight & PCV Idea
1995 850 turbo
when I turn the key to the "ON" position even without starting the car, there is a grinding noise from behind / under ??? the pass. side headlight. What is this? It can be heard when the car is started also.
Also, has anyone ever tried to bypass the PCV system by re-routing any part of it of by trying to actually retrofit a PCV valve or is this just crazy thinking? Just curious because I spoke with my mechanic today and he said he has successfully re-routed the hose coming out of the front of the valve cover to a vacuum port in the breather box. He said he's done this on several cars and has had no problems whatsoever. He said everything runs back through the intake and any particles are burned just like a regular PCV system.
S70driver
10-03-2006 12:00 PM
