high rev idle at start up only - Volvo Forums - Volvo Enthusiasts Forum
LinkBack Thread Tools Search this Thread
Old 05-08-2007, 12:57 AM
Default high rev idle at start up only
Hi:
Any ideas on why my 850 turbo revs 1500 for the first 5 secs when starting, then settles down to a smooth 800 RPM. Can't be good on the engine!
Not sure where to look?
Thanks
Pete
Old 05-08-2007, 11:27 AM
Default RE: high rev idle at start up only
Nope!
As far as I knowturbos are programed by the EMS (Engine Management System) to doexactly that.
Mine does exactly the same thing as yours on start-up,now has 210,000 kilometres on the clock, andruns beautifully.
Old 05-08-2007, 01:06 PM
Psaboic's Avatar
Yep, Normal.....
Old 05-08-2007, 08:55 PM
Thanks for the comments. I will no longer worry about it!
Old 05-08-2007, 10:13 PM
Do yours all stay that high for 5 seconds?
Because right when I start up, I'll hit around 1200 or so, and then it will settle down.
It doesn't stay there...
Old 05-08-2007, 10:51 PM
That sounds about right for my turbo.
Old 05-09-2007, 06:21 AM
JPN's Avatar
JPN JPN is offline
It is fast idle system. Many engines are designed to idle at higher RPM when the engine is cold. Mostly the duration & RPM is set by the ECU, so there may be some differences from one car to another. I noticed, however, that 850 turbo (B5234T) engine's fast idle is very short in duration, as compared to some Japanese cars (e.g, '05 Toyota Corolla idles at approx. 2,000RPM and takes several minutes until the RPM drops to normal idle speed (750-850RPM) in freezing climate.
As agreed by all, it is absolutely normal and nothing to worry about, including Jimmy & BriGuy's case.
Good day,
JPN
Old 05-10-2007, 05:35 PM
Has anybody had this happen, the car is relatively warm (run within the last 1/2 hour) It starts and goes to an idle around 2500rpm's and stays there, as soon as I put it in drive it goes to normal. It happens infrequently but bothers me nonetheless. Is this a TPS thing or coolant temp sensor? Any help?
Thread Thread Starter Forum Replies Last Post
hard to start and cannot rev Syukri Dhm Volvo 240, 740 & 940 3 05-22-2012 08:02 AM
Idle/Rev Issues - Quick Response APPRECIATED sadie41 Volvo S80 7 10-10-2011 11:55 PM
High Idle only in Park and Neutral SkyVolvo Volvo 240, 740 & 940 1 02-17-2011 01:48 PM
High rev on start kgolsan Volvo 850 7 12-14-2008 11:35 AM
High rev before acceleration yobea Volvo S40 2 09-27-2007 04:16 PM
Tags
05, 850, fast, high, idle, rev, reving, rpm, s60, s80, sound, start, startup, volvo, wagon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
