04-16-2009, 11:19 PM
How to Clean PTC on a Volvo 850
What is the procedure to remove, clean and re-install the PTC? PTC is part of the PCV system?
04-17-2009, 09:53 AM
Take out the intake hose i.e. the one from air filter box to the turbo inlet after disconnecting the electrical connector and 2 tubings from the PTC. Now once its out, carefully remove the PTC from the hose specially taking care of the rubber gromet that holds the PTC onto the intake hose and give it a nice flush with carb cleaner or brake cleaner. You might fint the narrow hole for one of the vaccum line blocked or abstructed. The installation process is just the reverse order of removal but I actually added 2 cable ties to hold the PTC on to the hose because the gromet was not in perfect condition and have also used some black sealent between gromet and hose.
__________________
A NOVICE striving to b EXPERT on :
1994 850 Turbo with 200k kms.
1997 850 Estate with 180 kms.
04-18-2009, 12:26 AM
What does this PTC do???
__________________
94' volvo 855 = 16T, inmotion ECU w/17psi tune, MBC
98' volvo S70 = stock
85' C10 Pickup = solid roller 406,alum heads,posi,etc...
73 Kaw 900 = 1075 kit, 38mm mikuni's, widened wheel,etc...
04-19-2009, 12:45 AM
Is it necessary to remove the intake hose? The PTC is clearly visible/accessible. from top.
04-19-2009, 01:00 AM
04-19-2009, 09:40 AM
Thanks denver005! Thats a good link.
__________________
Tags
850, c7026, clean, cleaner, cleaning, forum, hose, intake, procedure, ptc, ptccleaning850, removal, removing, turbo, v70, volvo  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
