How to remove alternator??? 1997 850r
I'm trying to replace the alternator on my 1997 850r. I read the Chilton's manual. It says to remove the alternator bolts and the powersteering pump and bracket will come out together, which will give you access to the alternator.
I've removed all the bolts that appear to be holding down the powersteering bracket but it still won't lift out. How do I remove the alternator? Where exactly are the bolts located?
Thank you for your help in advance,
850rt5
12-06-2013 05:46 PM
cyberjpm
05-25-2010 12:07 PM
