Lack of power 1994 850 SE
Id like to thank the many years of silent help everyone on this site has done for me.
Vehicle:
1994 850 Sedan 2.5 SE
20 valve
B5252S
276K km
owned the best part of 11 years
So there is a lot of a back story to get here but to summarise:
car would stall on idle at stops randomly for the last year.
been in and out of various mechanics replacing:
MAP, finding out I don't have a MAF, Distributor cap and rotor button, cleaned plugs, replace 1 damaged lead.
After all the mechs gave up, I left it stranded at my parents house and over a few weeks, my tinkering dad thankfully found the culprit, a jammed idle air valve, cleaned it out and lubricated it with silicone.
Now it idles and stays running perfectly.
The problem now is that it revs fine and kicks down fine, but has underwhelming power, I can barely make it up a hill (70km/hr zone) I use to easily get above 90, now I'm lucky to stay above 60.
The throttle if I floor it and wont change up (might be a kickdown issue) but if I back it off just a little it will change fine.
I did a ECU reset on the weekend reading all the wonderful outcomes, have only had 2 key starts during its test phase, but still no luck getting up similar hills.
Read codes before and after, ones that remain (but may not have been cleared correctly)
A1
223 Throttle position (TPS) sensor signal too low
143 Kickdown switch faulty or short to ground
A2
cleared successfully
I also opened up the throttle body and cleaned the small amount of residual soot.
Its also worthy to note that the fuel consumption has gone up, but this may be because I'm revving it high but getting no response after 2500 rpm, it literally feels like that's the peak of it power.
the only things left that I can think of is:
a clogged catalytic convertor
low compression (one mechanic did test this 6 months ago and said it was good for its age)
Has anyone got any other suggestions?
Vehicle:
20 valve
B5252S
276K km
A1
A2
final (hopefully) update
An update for those who may have wanted to know.
It had been a lawn orniment for the last 8 months.
I found a genuin mechanic who thanked me for giving him the opportuinity to play with it.
Today i got the call saying it was ready to be picked up.
Still yet to pick it up and confirm his findings.
After all that it was a clogged Cat.
johnwilton
03-16-2007 06:52 AM
