Low Coolant light on, but level seems fine
Susan Marie Strait (05-07-2021)
RE: Low Coolant light on, but level seems fine
I have exactly the same problem with my 1996 850 Turbo.
Thininking that I had a defective coolant level sensor, bought a brand-new one, replaced it, but I still have the low coolant light on.
Based on what I've learned so far, I have 2 advices for you:
1) You might have a defective coolant level sensor. Lift up expansion tank to expose the sensor units (one on the left side is coolant level sensor) and remove the sensor for close inspection. If the sensor probe is brittle and damaged, you will most likely need a new sensor.
2) Inside the expansion tank, there is a magnetic float that works with your sensor unit to send a signal if you have enough coolant in the expansion tank. In my case, this magnetic float no longer floats any more and currently sits on the bottom of the expansion tank. So, my sensor thinks that my coolant level is low. When the magnetic float works properly, it should float to the coolant level in which case you should not see the low coolant warning light on.
At any rate, I am about to purchase a new expansion tank, since the magnetic float is shut in my expansion tank.
If you have fixed this problem already, let me know what/how you did it.
John
John
jherguth
09-26-2014 06:56 PM
