Ignition, ABS, burned-out bulb warning
This concerns a 1996 850, non-turbo, 220K miles. After I turn the key in the ignition to start the car, the ABS light turns on and the car won't shift out of gear. If I jiggle the key, the ABS light goes off, the car will shift out of park, but the burned-out bulb warning light comes on. This even though there are no burned out bulbs (headlights, turn signals, warning lights, brake lights). The bulb warning light stays on as I drive the car, which seems otherwise to perform as usual. I had a spare ignition switch (the electrical portion held in by two screws on the left side of the steering wheel) so swapped it out. That didn't make any difference. Ideas?
