95 850, no signal to injectors HELP!
Old 09-12-2012, 11:45 AM
rms1's Avatar
Default 95 850, no signal to injectors HELP!
I have a 1995 850, non turbo, automatic. We just replaced the engine with a junkyard one, new cap, rotor, plugs, wires, coil, FP relay, cam and crank sensors. I've double checked all connections. With a noid light im getting no signal to the injectors. The main relay "buzzes" with the key on. When I check the green wire with my test light the buzzing goes away. Good fuel pressure, runs off either but won't run on it's own. Car ran when it came in but had a bad rod knock so we replaced the engine.
Vmax
04-07-2014 07:42 PM
jea
09-11-2012 12:15 AM
scottvickers
10-26-2011 04:36 PM
B00$T CR33P
07-08-2010 04:04 PM
eboknight
03-22-2009 10:30 PM
Quick Reply: 95 850, no signal to injectors HELP!
