new issue, trans not shifting
Old 02-07-2012, 08:38 PM
nitrosport's Avatar
Default new issue, trans not shifting
you guys are getting tired of me by now im sure...
anyway, tonite i just went out for some burgers....
it is 20 degrees outside....
The car started off fine, but wouldnt shift out of 2nd gear...
but thats not the full description.....
It didnt want to engage the clutch until revs hit 2500ish.
Now, I put the shifter from D into 3rd and this cleared up the problem. It shifted threw all gears fine and the clutch engaged as it should.
This is the only time its happened. strange issue. any ideas?
I know I still have that trans code I need to look into. Need to figure out what sensor it is and possibly replace it.
I AM going to love this car....But its going to fight me 1st, lol
Old 02-08-2012, 11:25 AM
daver80's Avatar
Default shifty
nitro- If these 850s we own have a kick down cable like my old 240 (God rest her soul) you might check that it hasn gotten hung up and has slack. On my 240 the cable was hung up on a bolt or something and it wouldnt shift past second gear. Unhooked it and all was fine. easy thing to check. Dave
Old 02-11-2012, 09:40 AM
billymedic's Avatar
mine does this as well when it is really cold and i start it and take right off. (i dont like to do this but i run for a volly fire dept.) if i set and let the car warm before going it does fine. i thought mabye it needed serviced-fluid and filter change- not sure.
Old 02-11-2012, 10:09 AM
PNP Switch.
Clean fresh fluid doesn't hurt as well.
Old 02-11-2012, 10:43 AM
nitrosport's Avatar
Originally Posted by rspi
PNP Switch.
Yeh, Im gonna do both when I get the time.
Would electrical contact cleaning spray and a tooth brushed be a good way to clean the PNP?
I should have the repair manual early next week. but it doesnt sound to hard to remove the PNP switch.
Hopefully will be installing a boost gauge today.
Wont be driving the car anway till the new fuel pump arrives.
Old 02-11-2012, 10:56 AM
I seen good instructions on Matt's site. I'll dig a little more.
http://www.matthewsvolvosite.com/for...=2378&start=42
Here it is:
http://www.matthewsvolvosite.com/for...hp?f=1&t=29930
Old 02-11-2012, 10:26 PM
nitrosport's Avatar
thanx! that thread will help alot.
Looks like I will need to set aside a fair bit of time to do that job.
I have the fuel pump, main window switch block and interior light set as well as my OBD II reader all arriving this monday.
Hopefully by tuesday I will have a bunch of new parts installed and have it back on the road again.
Old 02-12-2012, 09:44 AM
gilber33's Avatar
I have an auto trans for sale if it comes down to that. Just sayin.
Old 02-12-2012, 10:28 PM
You can pull the PNP switch, clean it, and have it back in, in about 2 hours.
jasoncswafford
06-19-2011 04:16 PM
xeod
04-19-2011 08:27 AM
janeofdrama
05-24-2010 08:02 PM
kollynspringer
05-24-2009 07:09 AM
repeatclicks
09-03-2007 07:57 PM
Quick Reply: new issue, trans not shifting
