No spark from Ignition coil dam it!
Old 07-30-2009, 07:18 PM
redbottle's Avatar
Exclamation No spark from Ignition coil dam it!
I need electricity! I need it baaaddd! No freakin electricity man...I went to the local yard and spoted two 850 GLT's sitting ready for the pickin...I stripped them of all...ALL...relays for my 850...
why do I not get any spark in the coil? low voltage? battery too old? Just freakin cursed by the Volvo Gods? Help!!!!!!!!
94 850 T5
Old 07-30-2009, 07:33 PM
850tony's Avatar
check the battery voltage. if that is 11.5 volts or higher you *should* be ok there.
does it crank?
Old 07-31-2009, 07:21 AM
mikey78z's Avatar
also if your battery voltage is good... try disconnecting and reconnecting your crank sensor located at the top of the transmission where it bolts to the engine.... no spark means no crank sensor; no injector pulse no cam sensor
Old 07-31-2009, 07:36 AM
Psaboic's Avatar
Check the voltage going into the coil. Should be 11.5 volts or higher. If no voltage, you probably have a broken wire or bad fuse. If voltage going in to the coil is good, I would suspect a bad coil. Good luck
Old 07-31-2009, 06:17 PM
redbottle's Avatar
Thanks a mill, I will check the crank sensor. I've changed the old camshafts for another pair...the problem?. They were about the same wear. I have changed all of my relays and will install a new battery. thanks, can't wait to drive it, been waiting for a while now.
I'll do this Saturday
Old 08-09-2009, 04:06 PM
redbottle's Avatar
Default No spark ignition coil
I have changed the coil three times
I have changed the crank sensor
I have changed the cam sensor
I got a new battery...
It turns but does not turn on...
What can I do next?
Old 08-09-2009, 04:08 PM
redbottle's Avatar
Default continuation
I got a few trouble codes
144
212
213
214
433
444
I got a motronix 4.3 but socket 3 gave me all of these and the rest just blink like crazy
Old 08-09-2009, 05:52 PM
You changed the cams in the motor?
If so why?
Old 08-10-2009, 07:16 PM
redbottle's Avatar
Default Cams
my dumb/smart idea was to replace a pair of good cams with new o-rings since the original ones seemed to have the damn bolts welded to the cam...the wear seemed about the same(no micrometer test).
here I am with a bunch of extra relays (junk yard) one cam sensor that came off a T5 that does not fit mine because of the hull being too long?
Old 08-10-2009, 07:20 PM
Did you have either the cam sensor wheel or the Dist wheel off then reinstall it?
If so are you sure they are the right way?
They should only fit one way but they can fit both ways if you collapse the tabs when tightening them down.
Old 08-10-2009, 07:30 PM
redbottle's Avatar
Default Cams
I don't know exactly what you mean but...I made marks on my original ones then grabbed the new ones and held them on top of the corresponding cam and made a mark on the new ones... I parked the car took off valve cover, etc...I even took a freaking picture for reference...
I am kind of desperate now...
Old 08-10-2009, 07:34 PM
redbottle's Avatar
Default Cam
ah...yeah...I get your question now...I was thinking cams only not cam sensor...yes they only fit one way...but it seems that I had to push the T5 cam sensor too much so I stopped...the original cam sensor has a short lip, or face, the other even had a plastic cover on the outside... and the lip was like an inch deep as if it were to touch the rear o-ring...
Old 08-10-2009, 07:37 PM
redbottle's Avatar
Default cam sensor
no, I did not have the cam sensor off when I took off the camshaft. nothing broken...
Old 08-10-2009, 07:50 PM
Are you sure? I mean the metal plates held on with the single 10mm screw.
Old 08-11-2009, 12:00 AM
redbottle's Avatar
I'll take a pic of both cam sensors so you can scan them out. thanks for your reply tech
Old 08-12-2009, 08:03 PM
If you remove the parts you can see if the tabs are folded over. If they are wrong then that might be the problem.
  #17
Old 08-12-2009, 09:18 PM
redbottle's Avatar
Default Cam sensor
I used an OBD II and worked.
I got
P0326
P0400 and 420 ? It read knock sensor malfunction or absent.
I also got a shorted out part that I wrote down but don't have it handy right now.
check out the depth of the junk yard cam sensor that it did not fit.
the part that goes inside, or lip I guess, it is too long. my original is half the length of this one
Attached Thumbnails No spark from Ignition coil dam it!-dsc00516.jpg   No spark from Ignition coil dam it!-dsc00518.jpg
  #18
Old 08-12-2009, 09:32 PM
The part on the motor that goes into the sensor is what I was asking if you removed it.
That might be on wrong causing the issue. If the sensor came off a 850 it should work. The one without the black cover is an updated one.
  #19
Old 08-12-2009, 09:40 PM
redbottle's Avatar
I see, yes I did remove it and can't recall if I put it back the right way?
  #20
Old 08-13-2009, 08:32 PM
Pull it again and see if the metal tabs are folded over.
Quick Reply: No spark from Ignition coil dam it!
