Oil leaks from distributor, replacing seal pls help!
Old 07-03-2010, 12:49 AM
jiggadude's Avatar
Default Oil leaks from distributor, replacing seal pls help!
Hi guys
My 94 turbo has oil leaks coming out of the distributor and I'm planning to replace the rear cam seal but couldn't find a write up for this, I only found a write up for replacing the distributor cap and rotor. Can u pls give me an instruction how to take the seal off and put the new one in?
Thanks so much
Old 07-03-2010, 11:52 AM
gilber33's Avatar
Small screwdriver to pry it out. Grease up part of seal that rides on cam. Use large socket to tap it in.
DCampion
10-24-2010 02:39 PM
shansen5
08-08-2010 02:13 PM
STREETFIGHTER50
04-07-2009 12:21 PM
ricardonz
06-10-2008 09:31 AM
iwantansti
11-18-2007 09:16 PM
Quick Reply: Oil leaks from distributor, replacing seal pls help!
