Go Back   Volvo Forums - Volvo Enthusiasts Forum > Volvo Vehicles > Volvo 850
Sign in using an external account
Register Forgot Password?
Search
Welcome to Volvo Forums!
Welcome to Volvo Forums,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Volvo Forums today!
LinkBack Thread Tools Search this Thread
Old 08-01-2010, 06:12 AM
Default oil on top on engine
I am having oil pool up on top of the engine of our 97 850 glt, I am trying to locate the pcv valve,but unless thats its on the front I am unable to locate it.Can anyone help me on this,thanks
Old 08-01-2010, 07:06 AM
The pcv is on the front of the engine but underneath the intake manifold. It's difficult to see. There are a number of threads on how to replace the pcv. Took me just over 4 hours to do mine for the first time. I also had oil spilling out everywhere.
Old 08-01-2010, 07:53 AM
1995 Volvo 850
My Garage
Send a message via Yahoo to rspi
The best way to check the PCV system is to run the car warm then pull the oil dipstick out a little and see if you get smoke out of it. When the system is plugged it will cause pressure to build up in the motor and sometimes causes oil to escape from the oil filler cap and other parts of the engine. Worse case being the rear main oil seal (YIKES).
The PCV is a system not an item. It does have a oil trap box under the intake but that is only 1 component of the entire breather system. I'm somewhat of a slow worker so it took me 7 hours to do our S70 and 6 hours to do my 850.
If you don't see smoke coming out of the dip stick with the engine running, you may simply have a bad oil cap seal.
__________________
'95 850 T-5R Wagon - Panther - Daily Driver 22 / 28 mpg
'98 S70 GLT - Lil' Red - Daughter 22/30 mpg
My Volvo Video Channel - Used Parts For Sale - Interior Lights For Sale - ABS Light? Click Here - Men's Mentoring
Volvo's of time past: '87 740 GLE, '79 262C Bertone, '78 264, '95 960, '97 960, '98 S90, '98 S70 GLT, '95 850 T-5R Yellow...
Old 08-01-2010, 02:49 PM
kockyhardrockr's Avatar
1996 Volvo 850
Lumberjack Zac
Send a message via AIM to kockyhardrockr
Here's an idea you don't have to follow it, but when your PCV gets clogged and you put oil pressure into the system (hard acceleration) it will squirt out from under the oil cap in a fairly violent manner. if oil has made it up above the engine onto the insulation under the hood, good chance it's too much crankcase pressure from your PCV.
__________________
'96 Batmobile Volvo 855T Auto - 112,135 -
--Garaged until fixed
|DWS Extreme contact|Blue Torque Bushing|Cold Air Intake 3in|Stylin Vac lines|Genuine Volvo Plugs|Oil catch|Deer whistles FTW|
'96 Burgundy Volvo 854 N/A Auto - 225,000 - Junkyard
Old 08-01-2010, 05:25 PM
fcpgroton's Avatar
Platinum Sponsor
Another thing to consider is that the seal on the oil fill cap is bad and oil is leaking out of there. It does not take much to get the oil to pass the seal when the seal is bad. I would replace this first and see if the leaking stops before riping the PCV apart.
__________________
http://www.fcpgroton.com/creative/FCP_logo.png
Chris Augur 877-634-0063 ext. 303 | chris.augur@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
Old 08-01-2010, 06:17 PM
I pulled the dip stick and the fill cap while it was hot and running and just got very little smoke which would seem normal,but maybe not.I can smell it now while driving getting on the exhaust.I tried to search for a old thtread on PCV and could not find anything,but already my oil is down some on the stick.The seal under the cap looks fine,not brittle or missing pieces.
Old 08-01-2010, 09:30 PM
gilber33's Avatar
1994 Volvo 850
My Garage
Quote:
http://tinyurl.com/28rv3cn
__________________
Old 08-01-2010, 10:33 PM
1995 Volvo 850
My Garage
The PCV system info is in the Sticky Threads, Freq Used Threads: http://www.volvoforums.com/forum/showthread.php?t=26114
When checking the PCV system by pulling the oil dip stick out a little you should NOT loosen or remove the oil filler cap.
Again, you could have a bad oil filler cap seal.
__________________
Old 08-02-2010, 09:10 AM
I am having the smoke forced out of the dipstick tube too. And that's after doing my head gasket (and everything else) job, during which I removed and meticulously cleaned each component of the PCV system thoroughly. I cleaned the oil catch container, all of the lines leading to it, and the flame trap, until nothing else would come out when filled with degreaser. I could blow through it effortlessly afterward, and it air-dried for days in a position to drain out all of the residual water. I used a new intake duct (holes in the old one) that the flame trap attaches to the elbow of, cleaned everything attached to the intake, the hard-line going back to the exhaust manifold, EGR (which was totally gummed up), everything. I even cleaned out the gunk from the three orifices where the PCV container attaches (one up top and two on front) and ran clean diesel fuel through the front two of them (which ran right through and out the drain pan seemingly unrestricted) as part of the engine flushing I did before starting her back up (the top one was cleaned during my head cleaning). I was going to go back with synthetic oil since all of my oil seals are new (with the exception of the rear main) and it only has close to 111,000 miles on it. But if I have continuous pressure like this (which might weaken the rear main) I don't know that I want the high-detergent properties of the synthetic. OR, might the cleaning properties of the synthetic help "open it back up" as far as the PCV system is concerned? Everything else is at 100% and I couldn't be more pleased with the total job I did on this - except for this dipstick pressure still being present. We have put like 50 miles on it since finishing up the job. I am just scratching my head on this one.
Tracy
__________________
Tracy Faulkner
www.tracystruesoaps.com
Old 08-03-2010, 10:23 AM
1995 Volvo 850
My Garage
Hi Tracy, slow down a little. I wouldn't worry about it unless you are blowing your dip stick out of the tube. After replacing my PCV system I still had some smoke for about 1,000 miles. Give it some time before you start digging back into things, unless you start blowing your dip stick out.
Take it easy on the motor for about 1,000 miles (easy worm ups, no high rpms, etc.) then double check it. The smoke may just be that things are so new and needs to settle in.
__________________
Tags
850, 96, build, cap, deisel, dipstick, engine, head, oil, oiol, ontop, pressure, smoke, squirting, top, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
Secure Backup
