overheated and now coolant in oil
i was driving to the pick and pull - its 60 miles away
and it just needled in red i pulled over and popped the hood and the bottle was dumping all the coolant- so i let it cool down and refilled with coolant - i tested the thermostat and it works - new coolant lines - i think the timing is out- but i dont have the cam tool or any way to make one so i can fix it- i was told it is the timing being off
i wonder if not having a heater core is causing this too
i will try it again later today- but im getting a lot of steam in the oil but no back pressure in crank no bubbles in coolant from exhaust
im pretty sure its the head gasket - or at worst a cracked cylinder- but i cant tell-
there are no leaks externally- this will be a terrible thing if the cylinder is cracked
i dont know what to do - im so angry and im very upset that i put all my money into it and now this
before i junk it - do you have any advice
just checked the lower crankshaft timing mark - its off by 1 tooth time to pull timing belt and do it again but i don't think it'll do any good now when i pull the cam end off and redo the head gasket ( if i decide to) this time ill buy some metal dye and spray it in the cyls and look for cracks - its really good for showing them
as is for sale or swap for--------- volvo850 turbo wagon -black or red
answers to questions yes on pressure build up
not a lot of coolant but its there /steamy exhaust
yes im loosing coolant it boils out of the bottle
brand new thermostat tested and it opens wide
i set the timing to TDC ON THE TOP CAMS
CRANK MARK IS OFF BY ABOUT 1/2 INCH
i think i found out what the problem is "TIMING"
AM I GOING TO HAVE TO PULL THE TOP END ANYWAY AND DO A NEW HEAD GASKET?
big_k
12-10-2012 06:26 PM
crzicrzi
02-29-2012 10:41 AM
pierce
11-09-2010 02:04 PM
