P1618 Anyone else ever get this?
p1618 is usually a communication error code between the ecu / tcu and trans most of the time a bad connection
Some of the times it has to do with the abs module but Its hard to tell unless you have a tester abs module. it could be anything from the pnp wiring to a corroded pin on the ecu or abs module
Your two codes arent connected.. The p0172 has to do with a O2 sensor, which most likely need cleaning or replacement.
Have you tried to clear the code and see if it comes back?
stevo77
01-28-2008 08:34 PM
