PLEASE HELP...What do these engine fault codes mean
Can someone help. We just replaced the transmission on my 850, have a new radiator, new starter, and have checked out fuel pump pressure. New crankshaft sensor. Battery is fine too. The problem is that the car is not getting any spark. I have had this at 2 shops, and no one has been able to help. (Neither checked the OBD - I did this myself.)
Did the OBD and these are the codes:
in the 3 socket
4-4-4 I know that this is saying that there is no power supply to valves in hydraulic unit. What could be wrong here?
In the number 7 socket, we got the following:
122 - Temp. sensor interval too long
113 - Fuel gauge open circuit
231 - Vent damper motor position open circuit or short to 12 volts
Any ideas as to why we would be getting these codes? I have a 1995 850 GLT 2.4l non-turbo.
thanks!
beth
in the 3 socket
thanks!
beth
atikovi
08-17-2006 10:20 PM
